Good afternoon,
I have a couple of questions and proposals related to the phenomenon of galvanic corrosion that I would like to know your opinion.
Context: At the moment I have a cast iron pump, 3 way valves in carbon steel flanged, other 2 way valves in stainless steel, carbon steel piping and some accessories (pressure gauge, level gauge, etc.) in stainless steel. With these materials, I want to assemble a small plant for the transfer of fluids (aromatic hydrocarbons C10 more or less) that will be outside (humidity, rain...but not sea water).
I have always been taught that it is not ideal to mix materials when dealing with metals with different potential to avoid corrosion phenomena, but here I have several doubts:
In principle these are the doubts that I would like to corroborate. I don't have much knowledge in terms of corrosion, so any opinion or comment is as always welcome.
Thank you guys
Kind regards,
- If the connections between the valves and the piping are by flange (one flange would be carbon steel and the other stainless steel), is it enough to put a dielectric gasket to avoid galvanic corrosion? Or is it advisable to coat everything with some kind of paint?
- If the connection between the carbon steel pipe and a stainless steel valve is welded, would it be enough to use some kind of welding material to insulate the two metals?
- In the case of buying new valves, I understand that it would be better if they were made of carbon steel as the pipes, but if it is not possible, I understand that between cast iron and stainless steel would be better cast iron because it has a potential difference more similar to carbon steel, right? Nevertheless, In terms of INTERNAL corrosion between the material and the fluid, obviusly stainless steel is preferable to cast iron, but I don't know if it compensates due to higher galvanic corrosion between stainless steel and carbon steel
Thank you guys
Kind regards,
