G81 Drilling Canned Cycle (Fagor 8055 M)
  • Thread starter Thread starter mediumsliced
  • Start date Start date
M
mediumsliced
Guest
Hi all, I have a question for y'all.
This is regarding the G81 drilling canned cycle. According to all the texts as well as my test posts, a sample output comes out as:
N5550 G81 X12.7 Y12.7 R-5.0 Z19.503 F100.0
I'm trying to customize a post for a Fagor 8055 M controller and according to the programming manual, the G81 canned cycle G-Code required by the controller should be in the form of:
G81 X Y Z I K
Where,
X & Y = movement of the axes
Z = ref. plane coordinate
I = drilling depth
K = dwell time
I presume this can be achieved by means of FIL macro programming? If so, can anybody give me some pointers as to how to achieve this?
TIA!
< = defer>
Hi Tia
Zaki,
Thanks for your reply. Can you please elaborate more on your statement? I know I can change to IJK manually, via the controller, but I would like to have the either PP or FIL make the necessary changes.
And when you say customize canned cycle, is that in the controller, or in the CAM system?
Forgive my ignorance. Just starting out.
In order for Proe to output a "DWELL" within the CL file, you will have to use a cycle type that has that parameter, in this case I chose the "CYCLE/FACE" type for the NC sequence.If you want to choose a different one, just alter the code where it looks for the cycle type. You will have to create or modify your FIL file to capture this cycle type. Following is one way of doing that:
$$ * G l o b a l V a r i a b l e S e c t i o n *
A=1;B=2;C=3;D=4;E=5;F=6;G=7;H=8;I=9;J=10;K=11;L=12;M=13;N=14
O=15;P=16;Q=17;R=18;S=19;T=20;U=21;V=22;W=23;X=24;Y=25;Z=26
REDEF/ON $$ Allow redefinition of variables
CYCTYP=0 $$ Switch for CYCLE/DRILL
CYCDEP=0 $$ Cycle DEPTH
CYCDWL=2 $$ Cycle DWELL, set default to 2
$$ C Y C L E
CIMFIL/ON,CYCLE
DMY=POSTF(20) $$ Save current CL record
ARG1=POSTF(7,4) $$ Get first CL word
IF (ARG1.EQ.ICODEF(OFF)) THEN
IF (CYCTYP.EQ.1) THEN
CYCTYP=0
POSTN/OUT,G,80
ENDIF
ENDIF
IF (ARG1.EQ.ICODEF(FACE)) THEN
NW=POSTF(5) $$ Get # of arguments in CL record
LOOPST $$ do loop to parse the cl record
DO/REDO3,N=5,NW,1
TWRD=POSTF(7,N) $$ get the next cl word
TTYP=POSTF(6,N) $$ get the next cl word type
IF (TWRD.EQ.(ICODEF(DEPTH)).AND.TTYP.EQ.0) THEN
CYCDEP=POSTF(7,(N+1))
ENDIF
IF (TWRD.EQ.(ICODEF(DWELL)).AND.TTYP.EQ.0) THEN
CYCDWL=POSTF(7,(N+1))
ENDIF
REDO3) contin
LOOPND
CYCTYP=1
JUMPTO/SKIP1
ENDIF
DMY=POSTF(21) $$ Restore current CL record
DMY=POSTF(13) $$ Process current CL record
SKIP1) CONTIN
CIMFIL/OFF
$$ G O T O
CIMFIL/ON,GOTO
DMY=POSTF(21)
XX=POSTF(2,1,1867,1) $$ SUPPRESS TAPE OUTPUT
DMY=POSTF(13) $$ PROCESS TOOL CHANGE
XX=POSTF(2,1,1867,0) $$ RESTORE TAPE OUTPUT
CURX=POSTF(1,3,344)
CURY=POSTF(1,3,345)
CURZ=POSTF(1,3,346)
POSTN/OUT,G,81,X,CURX,Y,CURY,Z,CURZ,I,CYCDEP,K,CYCDWL
JUMPTO/SKIP2
ENDIF
DMY=POSTF(21)
DMY=POSTF(13)
SKIP2) CONTIN
CIMFIL/OFF
thanks, will give it a try and update everybody.
it's getting pretty hectic now. apart from the fagor controlled machine, i have to work on another machine, a taiwanese machine with a mitsubishi 65SM controller, but that's not it, the screwed up thing is that the controller manual is in mandarin, and i don't read mandarin!
Edited by: mediumsliced
Hi Tia
Man I means that u can change via pp. While in mfg file open go to applications>>nc post processor, and make a new prosessor as a copy of an old one. then make the neccassory changes. Its not so difficult, just need to surf it.
i know, but the OFG is rather limited in the amount of customization allowed. in the end, i still need to touch fil. :(
