G10 L12
JeniaL
IL
how can i set post builder to output right after tool list or
before or after tool change such a code G90 G10 L12 PXX RXX
PXX XX=tool number, RXX xx=tool radius
seems to be pretty easy to output this code but my problem is first tool.
instead of first tool radius post outputs last tool radius value
N3 (TOOL #2 DRILL-2.5 )
N4 G90 G10 L12 P2 R3.000
R3.000 for a drill dia. 2.5mm???. last tool in the program is end mill dia. 6.0mm
post and file attached
 http://files.engineering.com/getfile.aspx?folder=4e4e14ce-59b7-46f3-812c-4d32aabc5dce&file=Haas_3Axis_WTL.zip
