Friction in MDO W3...
  • Thread starter Thread starter SlavoM
  • Start date Start date
S
SlavoM
Guest
Hi all,
Do you someone know tell me why PTC in MDO W3 removed ability of firction definition from dialog of axis prop. setting? (translation axis of planar joint)
Now in W3 I must use alternative technique for simulation of disk brake system...
Thanks for all responds.
Slavo
Friction definition and joint axis settings are now from the dashboard for assembling a component. I think the idea was that users should be able to define that stuff for connections in Standard mode as opposed to having to enter Mechanism mode. So the functionality is still there, you just do it from a different location.
