P
prdtro
Guest
I need to create a drawing & model of a flanged bushing in it's free as shipped state for purchasing to order the part. I also need to have a installed model as well to assembly in to my assembly. The way it works is after the bushing is installed, the excess material that sticks out past the boss of the part, is rolled over the boss. So the bushing is captured in the bore. We don't use family tables where I work, so that doesn't appear to be an option. I tried creating one model with both free & installed features, and put them on layers to switch between the two states. But when I blank a layer with solid features, they don't seem to blank. I also tried using Simplified Reps, that works with the part and drawing, but when you assembly it, you can not choose what Simplified Rep in the part to use in the assembly. Does anyone have any thoughts on this one? Thanks!
Ted
Ted
