Formulas basic question 1
JT1982
5
Hi
Is there a good place to look at the basics of the available function options for NX/MCD? I am new to these.
For example I am trying to use a bool condition to set a value but I don't want to use the "else" part of the function to change it back once the condition goes false:
IF (GO_TO_POS_1=1)THEN(100) ELSE (0)
Removing the ELSE to give just (GO_TO_POS_1=1)THEN(100) isn,t accepted.
If someone could help with this particular problem would be great but somewhere to reference to for future questions would also help alot.
TIA
Justin
Have you read the doc's?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi
I did access the help file in the signal adapter/formulas area but it doesn't go into this. What docs are you referring to?
While in the Expression Editor, hit the 'F1' button and see what comes up.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi, I tried that, it just brought up the same help page as pressing the "?" button. It doesn't go into formulas.
