4
4l3x4ndr3
Guest
Hi
my problem is that all my parameters are unavailable and invisible from any menu I've tried (f(x) button, right-click and edit formula). If I manualy create a parameter like ratio or something, it will appear in the tree. When I open the formula dialog box (as I've mentioned previously), I can only see the latest parameters (like atio). I tried saving the part, product, change the filter, check or uncheck fields in the options, but it didn't do a thing.
Also, what bothering me is that it was working yesterday. If I create a new product, there is the same trouble. Something special is that all the formulas previously written (like yesterday) aren't visible (well I mean, I can chage the value in the user defined parameter but I can't see the links and writings in the formula box) but still act parametric.
Thanks for help!
Thanks for help!
