force question
  • Thread starter Thread starter sagrob
  • Start date Start date
S
sagrob
Guest
Hi All!
I'm designed a cutter. I want to calculate the reaction force at the edge, or poit. I know, the hydraulic pressure is 320 bar.
Sorry for the picture :)
Thanks!View attachment 2622
Looks to me like you simply need to do some statics to find the resultant for at the teeth. You know the hydraulic pressure in the cylinder which will give you the axial force on its output shaft. Use that in a force balance on the cutter and solve for the force on the tooth.
bkjensen
Thaks for your answer. It works good!
Hi dear
What is all this, I am new to analysis, can u guys explain this briefly.,, how to calculate all this & what r the constraints u have taken & how.
sudhanshu@desmania.com
thanks & regards
