Helepolis
- Dec 13, 2015
- 208
Hi all,
I'm looking for a fluid flow meter for high frequency oscillatory flow, with data logging capabilities (preferably using a memory card).
The flow meter is intended for an experimental system as part of a research (biomedical).
A bit of the experimental characteristics:
f[Hz] 8-12
Q[ml/s] 2.5-9.5
Re (reynolds number) 144-2300
D[mm] (tubing) 8
Basically we want to hook up the flow meter to our system and log the flow characteristics for later analysis.
Any leads on a possible company, product line or a specific product will be appreciated.
SD
f[Hz] 8-12
Q[ml/s] 2.5-9.5
D[mm] (tubing) 8
SD
