FLuent For CATIA....
  • Thread starter Thread starter handa
  • Start date Start date
H
handa
Guest
Dear everybody!
I try to install Fluent for CATIA V5 R15. But when I try to
run an analysis, there is an error (dialog box displayed). It was
stated that :
" Entry point not Found
The procedure entry point
?SupportFileSaveMgt@CATSamDocume ntTool@SAJPAVCATDocument@@AAVCATUNicodeSTring@@Zcould
not be located in the dynamic link library CATAnalysisToolkit.dll "
I need some helps...!
What should I do to solve that problem??
Thank you very much......
Hello!
me happends the same!
Have you already solved this? i'm more than interested in run fluent for catia. I need help too!
Someone who could help us?
Hi
I have the same problem.
when I run the Ffc,there is the same messge as yours and with ignoring that the main tools are not active.
Have you alredy found any solution?
I have the same problem with Ffc-R15-1.0.8, after installation appears the same message as handa has stated in the 01 December 2006 post:
"Entry point not found ......"
and the icons in the toolbar remains dimmed.
Does anyone knows whatto do to turn Ffc active.
Thank you very nuch for your help
I see thatsome peopleare using Fluent for CATIA V5 R15. In materialfor install Ifound thatused to be changedfile R15 to R16 in Program files/..., depends on which version (V16) is to be add, right?Could it make problems in using, as you wrote?
By the way, where could be find some Fluent for CATIA tutorials?
Thank you in advance!
Hi
I am installation Fluent for CATIA V5R15 but no running.
It was stated that :
?SupportFileSaveMgt@CATSamDocume ntTool@SAJPAVCATDocument@@AAVCATUNicodeSTring@@Zcould not be located in the dynamic link library CATAnalysisToolkit.dll "
Are you successful for installation?
Please help me for installation.
Very Thanks
Best regard.
Hi
?SupportFileSaveMgt@CATSamDocu me ntTool@SAJPAVCATDocument@@AAVCATUNicodeSTring@@Zcould not be located in the dynamic link library CATAnalysisToolkit.dll "
Very Thanks
Best regard.
Hello!
m
mermaid bridal gowns
wedding dresses mermaid e happends the same!
do You know how to fix it ?? or run FFC v5 r18 ?? help please .
