Flow Simulation
  • Thread starter Thread starter kenjg
  • Start date Start date
K
kenjg
Guest
Hello All,
Thank you in advance.
I just started using Flow Simulation and I would like to know if there is a way to simulate Air traveling thru a tube and out the other end of a nozzle with a pattern of hole in it. I want to know what the Air will look like, meaning projected on the output end of the tube. For example, if I add different size holes and different angles to them, what would it look like.
I'm sure more info is needed, so please ask and I can explain to send some sketches.
KenG
SolidWorks 2013 Premium
Hello All,
KenG
change to fluent :D because solidworks flow simulation dont have tools for advance mesh
