Flow simulation (Tanks)
  • Thread starter Thread starter Jeeng
  • Start date Start date
J
Jeeng
Guest
Hello!
I need help to simulate the flow of a fluid with "flow simulation - Solidworks".
The system works as follows:
the fluid enters the tank 1, passes inside the pipe and goes into the tank 2, and so on. The tube was done using the "routing" of pipe.
In solidworks:
Go on options> add> flow simulation
# Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting. UpaBMuIl9po
I click wizard and put the specifications, in which case I used SI unit system and used as fluid "water"
scheme is as follows:. Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting # UpaC6uIl9po
After closing all entrances of the tanks, I select to enter and exit flow, but can not create a system fluid from the tank 1 pass into the pipe between the tank and 2.
# Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting. UpaGKeIl9po
how to create a system that fluid between and fill the tank 1 and go into the pipe and fill the tank 2 ?
Thank you.
