Flocked Coating on Sliding Rubber Seal
smyluk
Industrial
Apr 10, 2024
1
Hello
I am looking for a second opinion on alternatives to a flocked coating on a rubber seal.
I have been speaking with a potential custom rubber seal manufacturer who advises that the best solution is a flocked coating to avoid friction and dragging. However, their minimum order quantity is 100 metres, which is significantly more than the length we need for our initial testing.
Whilst I agree this is probably the best solution, I was wondering what other options could be applied to EPDM rubber that would allow glass to slide over the top surface without friction.
What are you sealing? Flocking will prevent a bubble tight seal. Grease will work but can get messy. Talc powder can work similarly to flocking. It will wear away faster but can be easily applied.
Can you use a grease or does the lubricant need to be dry?
Soap and water would be my suggestion. Or a propylene glycol and water solution - we use that for orings when customers want a silicone (our usualy oring lube) free product. Silicone spilled on a concrete floor is pretty slippery, but propylene glycol spills are slicker than snot.
