FlexLM
  • Thread starter Thread starter bernhardm
  • Start date Start date
B
bernhardm
Guest
Hi!
from a single Client ptcstatus shows the following outputs (short version):
Code:
License Server is UP:
  Warning (-96): License server machine is down or not responding.
 See the system adminstrator about starting the license server system, or
 make sure you're referring to the right host (see LM_LICENSE_FILE).
FLEXnet Licensing error:-96,7.  System Error: 11001 "WinSock: Host not found (HOST_NOT_FOUND)"
                      License    In Use   Free
                   ISDO_II_SET*       Counted
                     PVMCADPRO        Counted
      ProductView_Professional        Counted
FlexLM lmadmin 11.14.
But I can start Creo 2.0 M250 and get a valid licenses. Other Clients on the same network work as expected - showing the used / free licenses.
What does the "counted" mean in general? I get this message on another license Server too. But this on is realy down/not working properly.
br Bernhard
