Flexible hose inspection requirement 1
MATEGRITY2009
Petroleum
Oct 9, 2009
43
We facing with the problem of How to inspect in-service flexible hose in oil & gas industry and acceptance criteria in case of hose minor damage eg. Crack at outer rubber cover, slight corroded on metal wire brided etc. My question is;
-Is there any reference Code, guideline or standard available for in-service inspection of flexible hose?
-If no, What is the best pratices to manage the integrity of the hose? (inspection interval, acceptance criteria, inspection/ testing technique)
Thank you
IMO, may consult with the hose vendor for the inspection, repair, and replace guidelines. I don't know if any Code applicable for the inspection. Depending on the consequence of the liquid/gas leaking per process as well as P&T, the hose may need to be replaced even just a minor cut damage.
