Aug 18, 2006 #1 C cadaddict Guest Does anyone know of a VBA program that creates a flat pattern from a 3D solid in autocad (not inventor)?
Aug 24, 2006 Thread starter #2 A ahittle Guest Striker Systems There are third party programs that will work with autocad to unfold a 3d solid, the I use is Striker System.
Feb 14, 2008 Thread starter #3 G GREYWETHR Guest Need more info, but... ... if you just mean make a 2D drawing from a 3D drawing, there are numerous ways to do it within ACAD. FLATTEN: NOT for large drawings SOLVIEW/SOLDRAW SOLPROF Check these out and see if they're helpful.
Feb 15, 2008 Thread starter #4 C cmlucifer Guest Give it a try You can also try the SECTIONPLANE command if your using Auto cad 2007 or 2008. It will generate 2D blocks depending where you place your section plane on your model.
