Pud
- Mar 26, 2003
- 2,707
Our sales guy has volunteered us (i.e. me!) to redesign a flag pole support.
To keep it simple, imagine a tubular socket on a flat plate of infinite thickness, the socket having a length of 290 mm and an internal diameter of 60mm.
There are various length poles with various size flags on the top. The flag pole manufacturer has given a maximum bending moment for the flagpoles of 2.18KnM
I am looking at using a material with E=17000MPa and Tensile strength at break of 220Mpa.
Assuming a transition fit of the flagpole in the socket, what will be the minimum required socket outer diameter.
Assume ideal everything – I'll add safety factors.
Cheers
Harry
Cheers
Harry
