Fixture offset G43
  • Thread starter Thread starter the_real_jat
  • Start date Start date
T
the_real_jat
Guest
wasup
i am in big trouble with my posprocessor. I am using
CIMFIL/ON, SET
IF(POSTF(6,5).EQ.1)THEN
FIXT=POSTF(7,5)
REPEAT/OFF
REPEAT/X,Y,G,FIXT,ALL
ENDIF
CIMFIL/OFF
and now i give a parametric value to my fixture offet in the Pro/NC while defining sequences.
For some reason, my output file gives warnings now. and it doesn't even show the G54 that its supposed to show.
Anyone aware of this?
thanks
~JAT
I didn't know the "REPEAT" command could be used for anything but text. But if it works, you might try this instead of your macro.
CIMFIL/ON,SET
WORD1=POSTF(7,4)
IF (WORD1.EQ.(ICODEF(OFSETL))) THEN
TYPE2=POSTF(6,5)
IF (TYPE2.EQ.1) $$ Is it a real number
FIXT=POSTF,7,5)
REPEAT/OFF
PREFUN/FIXT,NEXT
REPEAT/X,Y,G ,ALL
ENDIF
ENDIF
CIMFIL,OFF
I tried using the Repeat command, but I couldn't get it to work either. This is what I have in my FIL file. Why don't you try it and let me know how it works for you.
$$ S E T
CIMFIL/ON,SET
WORD1=POSTF(7,4)
WORD2=POSTF(7,5)
TYPE2=POSTF(6,5)
IF (TYPE2.EQ.1) THEN $$ IF ARGUMENT IS A REAL
WPC=WORD2
WPCMOD=-1
ENDIF
ENDIF
CIMFIL/OFF
$$ G O T O
CIMFIL/ON,GOTO
DMY=POSTF(20)
IF (WPCMOD.EQ.-1) THEN $$ First GOTO after WPC change
CURX=POSTF(1,3,344)
CURY=POSTF(1,3,345)
CURZ=POSTF(1,3,346)
PREFUN/WPC,NEXT
POSTN/OUT,X,CURX,Y,CURY
POSTN/OUT,Z,CURZ
WPCMOD=0
JUMPTO/G01
ENDIF
DMY=POSTF(21)
DMY=POSTF(13)
G01)CONTIN
CIMFIL/OFF
Edited by: appinmi
