dthom0425
- Dec 6, 2018
- 47
Hi all,
I am attempting to use Y14.5-2009, Appendix B.5 "provision for tilting of the axis or center plane when projected tolerance zone is not used" formula to calculate the max shaft dia on my screw.
The only problem is I'm getting an unexpected result. I may be choosing the wrong variables or maybe the equation needs to be modified for my part.
I attached a cartoon of what I'm working with.
Black = housing, tapped for a 6-32 (1.5D) helicoil.
Green = the 1.5D helicoil (6-32)
Orange = top plate. The hole in the center is tapped 6-32 (to essentially captivate the screw once you thread it through the top plate).
Blue = captive washer
Red = 6-32 threaded captive fastener with a necked down portion. The necked down portion is free to move diametrically in the Orange (top plate) 6-32 thread minor diameter.
I am using this formula: H=F+T1+T2(1+(2P)/D) .
F = max diameter of fastener. I am trying to calculate this value
H = minimum dia of clearance hole. For this, I was using the tap drill size (orange plate 6-32) of a 6-32 thread since the tapped hole in the orange part essentially becomes a clearance hole that the necked down shaft of the screw must lie within.
T1 = positional tol dia of the clearance hole. For this I was using the pos tol of the 6-32 thread in the Orange top plate as that is what the screw needs to clear in the mating condition.
T2 = pos tol diameter of tapped hole. For this I used the pos tol of the helicoil.
P = max projection of fastener. For this I used the distance between the top of the helicoil to the bottom side of the head of the fastener (top of helicoil to top of washer).
D = min depth of thread. For this I used the 1.5D length of the 6-32 helicoil.
Does anyone see anything wrong with this approach? The max diameter I end up calculating is way small.
