B
bac478
Guest
I am working with an assembly that was likely modeled on a version of Pro preceding WF4 and by an unknown designer/engineer. We have some pretty complex models and sometimes it is easier to just copy them and make small modifications than to start from scratch. At any rate, The first component in the assembly seems like it is lacking a definition. When I attempt to right click and look for the "edit definition" option in the menu it is missing along with "edit references" and "make flexible" options. This leads me to believe the component has no placement constraints, but it also doesn't have the small black box in the tree indicating an under-constrained part. Has anybody had a similar problem? Is there an explanation?
I am currently using WF4 to try and edit this assembly, but like I said, I have no idea what version is was created in or what it's history looks like.
