Finding Top-Level Assembly
  • Thread starter Thread starter shtern
  • Start date Start date
S
shtern
Guest
Dear all,
is there a convenient, automatic way, given a folder of models (parts and assemblies), to find out what the top level assembly is?
Is there a way to get the whole hierarchy, without opening the top level assembly in Pro/Engineer?
Thanks in advance,
CR.
There is good news and there is bad news!
The Good news: Yes you can find the top level assembly and the hierarchy of an assembly.
The Bad news: You need to spend more money, as you will need to purchase one of PTC's database managers for placement of the files so you can run reports.
Intralink is a good choice for you. it will generate BOMand all you want automatic.
I use a program called FINDMYMOTHER, it is free and works well
it seems even in software father is less important
what a ...(add here what You want)
looks intresting indeed
mothers will have more weightage
Edited by: rudresh.hm
I used to always do searches for text strings in the assembly file headers for part names but at some point the MSWindoze search function quit functioning (thanks Mr. Bill). So I have been using FindMyMother which works pretty much the same way & continues to work. The interface is a little convoluted but it is a useful tool if you don't have a PDM system.
It won't give you the hierarchy though, just a list of all assemblies or drawings that use a given part.
