Finding grouped components in Model Tree
  • Thread starter Thread starter USG-CY
  • Start date Start date
U
USG-CY
Guest
Hello everybody, We're working with WF5 (Creo Elements). I've got the following question for you:
Is there a way to find a grouped component in your model tree? I would like to select the component in the modeling screen, then use some kind of mapkey to show it in the model tree.
So it should always pop-up, even when it's in a group in a subassembly.
Looking forward, to see all your sollutions!
Cyriel
Dear USG-CY
Whenever you form a group , then there is always (+) symbol on the left of it.
Just click it , You will get all the components in it
Edited by: EagleEye
Edit>find
OR
ctrl+F
Thanks for your replies, but but that's not the way I need.
When I have a assembly on my screen, I see a washer in it and want to know the location of this washer in my model tree. I don't know where it is in my model tree. There could be 30 groups in the model tree. I don't want to open each and every group to find it. I want a button/mapkey with a name like: FIM"Find In Model tree".
Offcourse I know where to find the Find-function. But then I have to do a lot of "click's" and type in the model name. When there are something like 100 washers in different groups, the find-function will find them all.... Not that specific one I highlighted in my model.
I hope my question is more clear now.
Thanks in advance!
Cyriel
sorry..i misunderstood your question before..it's very clear now what you want.
Finding component within group is difficult!
If it is in sub assembly it's easy by option: select parent and find it in model tree.
Let's wait, till experts say something about this!
Switch on the Preselection highlighting if it is not ON.
Any selection done on the graphic screen would then highlight the item in the model tree. As seen here, the highlighted item is buried inside the group. Hence the Group is highlighted.
Edited by: SRINIVASANIYER1
in WF-4 it's not highlighting items in group with this option.may be update in WF-5
You need the "one" icon.
With this icon, you can select a model or feature on the
screen, then hit the icon and it will jump right to it in
the model tree!
Go to tools/Customize Screen
Then to the Commands tab, select View under the
categories. Scroll almost all the way down on the Commands
lists on the right until you find the icon that says
"one". Drag that to a place on your icon tray. (Be careful
to choose the icon with the white dot, not the dark dot)
great..
Hi Nate,
your tip almost sounds like a practical joke,....
But perhaps it's a "Custom made"-button made at Brock Solid Design? If so, can you post the mapkey text from your config.pro
Cyriel
Edited by: USG-CY
It's not a custom "one"
I could find it! U check again.
Nate,
You're the best! I wasn't in assembly mode but in drawing mode, so I couldn't find it. Now I did! Super.
For the rest: Thanks for thinking with me!
That is great. Never bothered to delve into the built in
icons. This motivated me to explore. Thanks Nate.
the model tree!
WINNER
I couldn't live without this.
this button is very amazing , I like it, thanks for the
poster.
What about the other way around. I would like to select a part in the tree, then have the screen view zoom into the part. Inventor has a command by right-clicking and selctiong "zoom to". Anything like this in Creo/ProE?
<div style="text-align: left;">that's reallly help, thanks for your post
</div>
Spidernate,
Thanks for the tip. I've been looking for that solution for quite some time.
DennyE
A good question asked. I also got solution of my problem. Thanks to everybody.
"spidernate" nailed it. You need the "one" button.
