FILTER BLANK RECORDS IN A REPEAT REGION
  • Thread starter Thread starter maesoph
  • Start date Start date
M
maesoph
Guest
Dear All:
I have many tables using a repeat reagion to show the pin out of connectors on a harness drawing. Most of the pins on most of the connectors are unused and I wind up with a cluttered drawing filled with large tables mostly made of empty rows. I would like to filter by rule and ignore the emtpy lines. The parameters available to base the filter on are:
&mbr.connprm.pin.run.cond.name
&mbr.connprm.pin.run.cond.color
if either of the above is blank, I would like to skip that record in the repeat region. Thanks.
Mike
You can write an 'If' relation ...
Here is the relation side which I think is correct:
BLANK = ""
if mbr_connprm_pin_run_cond_name == ""
BLANK = 1
endif
The filter should work if it accesses the BLANK variable. What is the syntax for doing that?
Got it finally. I also had to change the relation to0
&rpt.rel.BLANK == 1
BLANK = ""
if mbr_connprm_pin_run_cond_name != ""
BLANK = 1
endif
