Fill gap between surface
  • Thread starter Thread starter Indyjet
  • Start date Start date
I
Indyjet
Guest
I have two lofts that are slightly different. I need to fill the gap between them to make a joggle. The joggle will be added to the purple surface to make it match the yellow surface. Can anyone tell me how to best accomplish this?View attachment 2199
If the gap is small, the Healing tool will probably work to close the gap by modifying one surface to match the other.
If the gap is large, you probably need to add some new surfaces between the two you have.
Hi Indyjet,
Healing assistant is definitely the workbench to use. You will have surface connection checker in it too.
I have a video but it is CATIA 3DExperience. However the methodology is very similar:
PLM Technology
