Is this a surface or a solid? If it's a surface, the 3D Wireframe option should be turned on.
Try some of the other view generation options. I think what you have in the upper-right corner (EXACT mode) is the best view for a drawing, although the upper-left (APPROXIMATE mode) looks identical to what you did manually.
