Feature Modification Problem....
  • Thread starter Thread starter Jimwxyz
  • Start date Start date
J
Jimwxyz
Guest
While modifying a sweep feature I am facing problem. Actually, it's a thin cut. When i open the sketch to modify trajectory I can't delete old references. The delete button simply doesn't work. Please, tell me what may I do wrong?
Hi Jimwxyz,
You wont be able to delete the old references if feature have been copied and is referenced by another feature. Try suppressing the copied feature and see if you can then delete the references. Of course, the copied feature will fail when you resume it, so you'll have to redefine it with the new references.
If you have patterned your feature, you won't be allowed to change the feature references either. You'll have to "Delete Pattern" (RMB selection) and then you'll be able to modify your references.
I think the same situation occurs when using grouped features.
