FEA Structural Example
JGard1985
189
Hi Guys
I'm looking for some suggestions on some challenging structural problems you've faced that would've benefited from a Finite Element Analysis.
I'm looking to demonstrate some FEA results against code predicted equations and incorporate into my firm's blog...something that can be shared without any concern for clients/customers Any suggestion is fair game...I'm leaning toward something out of AISC seismic design manual or other energy method
In the past we've covered:
[ul]
[li]Blast loading on buildings using LS-DYNA finite element analysis[/li]
[li]Bolted preload connections and prying resulting from thin flanges[/li]
[li] Using symmetry to reduce FEA run-time
[li] Validation and convergence of FEA models
[/ul]
Any suggestion is fair game and would be greatly appreciated.
Thank you
Jeff
Jeff
Pipe Stress Analysis
Continuous brick relief angles supported by askew headed bolts in a hohmann and barnard hw-340 or equivalent insert into a slab edge, 8" slab thickness, with a single or two stories of brick veneer, 10ft and/or 20ft. Two conditions angle flush to slab and angle outset with shim plates, up to 1", at the insert locations only. Angle orientation in either vertical leg up or down.
Open Source Structural Applications:
