A
Ascorti
Guest
Hello all and good day.
I have a part file, created in Wildfire 2.0,that I use for spacing components off of a base plate for fixtures. The dimensions of these parts is identical except for the thickness. What I want to do is to have the different thickness spacers show up as different colors in the assembly without having to go into the assembly and change the colors at that level.
I have the spacers set up as a family table and want to adda "color" column to the table so I can visually see the different thicknesses. There are times when I need to stack two spacers and I want to see the different thicknesses used.
Any suggestions will be greatly appreciated. Thank you all in advance for your help
