Failed Shell Operation
  • Thread starter Thread starter MotoEng
  • Start date Start date
M
MotoEng
Guest
Hi all!
I have a project I'm working on for a customer that involves some compound curves that are a little outside my comfort zone. The part has to be shelled as pretty much the last operation, but it fails to shell, giving me the following error:
____________________________________________________________________________________
Error Shell1 The shell operation failed to complete. One of the faces may offset into an adjacent face, a small face may need to be eliminated, or one of the faces may have a radius of curvature which is smaller than the shell thickness. Please use Tools Check to find the minimum radius of curvature on appropriate faces. If possible, eliminate any unintended small faces or edges.
I've been beating my head over this one for two days, so it must be something obvious that I'm just missing.
Can someone take a look at this model and suggest what the problem is?
https://1drv.ms/u/s!AtfE2uFNgBOWhxbdFpS ... u?e=88zJhe
THANKS!!!
