Samwise Gamgee
- Oct 7, 2021
- 118
I had a quick question about the need to use kickers to avoid torsion from the facade attachment. I have a slab cantilever of 6" over the beam for the slab edge all around the perimeter of the building. AISC design guide specifies that as long as the slab is designed as cantilever over the beam, no torsion will be delivered to the spandrel beam and kickers are not needed.
However if the steel edge member is used to transfer the forces to the spandrel, there will be torsion in the spandrel which needs to be resolved using kickers.(In case the slab is not designed as a cantilever).
My question is when would we even use this case ? Wouldn't it be ideal to just design the slab as a cantilever ? Also how does this apply to roof where we only have facade attached directly to the deck. What drives the need for kickers is what I am trying to understand.
