D
Darren787
Guest
I'm using a student version of Creo Elements pro 1 and I'm having trouble extruding from a surface that has a complex curve. None of the tips I have found work. One recommended to use the boundary blend tool but the one on my software doesn't highlight as one that can be used. Another suggested to use the offset tool and select the draft feature but I dont have that option. Is there another way to create a solid from a surface that is curved on two planes?
Thanks in advance!
Thanks in advance!
