strucbells
- Mar 25, 2020
- 177
Is it common practice or recommended to require a single or double polyethylene slip sheet for an exterior industrial slab on grade (no cover)? Basically a vapor retarder like for a building but the intent would be just to help reduce subgrade restraint for shrinkage and curling and help protect the slab from any unknown environmental durability issues from below (sulfates, etc.)
ACI seems to give clear guidance that vapor retarders do NOT cause curling like previously thought and some sources online claim they actually reduce curling, but ACI seems to hedge in a few places in ACI 360 and 302 due to possible impact on surface bleeding/finishing.
For context, current slab design is lightly reinforced (0.1%) with frequent sawcut contraction joints (enhanced aggregate interlock approach), placed over a 6" well graded crushed rock base. The slip sheets (if added) would go directly under the slab on top of the crushed rock base.
Seems like a minor additional cost if it helps reduce shrinkage cracking, but I haven't done a lot of these before so curious if they'll think I'm crazy for requiring it.
