Exporting body from a catpart file
  • Thread starter Thread starter MrCATIA
  • Start date Start date
M
MrCATIA
Guest
(I received the following question from Judah as a Private Message)
I am wondering how can I save or export an inserted body in a catpart file separately.
Let's say I have a body part and then I insert a body. At the end of my modelling, I would want to save this inserted body separately as a catpart file.
How can I do this or is it possible at all?
Thanks a lot.
Judah
Judah,
1. make a new Part file.
2. Copy the PartBody, and 3. use Paste Special, As Specified in Part Document.
4. you will probably get some errors about the sketches - just re-define each Sketch Support in the new Part file.
If the body is complex, you might want to use a PowerCopy instead.
