export of colored drawings?
  • Thread starter Thread starter troy
  • Start date Start date
T
troy
Guest
Is it possible to export my colored drawings out of pro by iges, dwg, or dxf?
Has anyone come up with any new methods of keeping the colors (model colors & text colors)assignedin a Pro-E drawingwhen converting to either .dxf or .dwg? Also, what about keeping text style? I have been playing around with this, and the best I could come up with was to iges, but then all my hidden lines are now white. I would like to be able to save to a .dwg, and have it look exactly like my Pro-E drw.
Tim
The colors of the drawing are when exported to DWG the same as in Pro/E. But, you can control colors of exported drawings with "dxf_export_mapping_file [path_and_file_name]" option and dxf_export.pro file, where you define color mappings.
Following is an example of dxf_export.pro:
map_color BACKGROUND_COLOR 186
map_color DIMMED_COLOR 1
map_color LETTER_COLOR 4
map_color HIGHLIGHT_COLOR 3
map_color EDGE_HIGHLIGHT_COLOR 7
map_color GEOMETRY_COLOR 6
map_color HIDDEN_COLOR 1
map_color SHEETMETAL_COLOR 7
map_color CURVE_COLOR 4
map_color VOLUME_COLOR 3
map_color SECTION_COLOR 2
map_color DATUM_COLOR 2
