Export BOM
  • Thread starter Thread starter idocadd
  • Start date Start date
I
idocadd
Guest
How to export a BOM from SolidWorks? Can I :
1. a copy and paste to the Windows clipboard
2. export to a CSV (Comma Separated Variable) file
3. an Excel spreadsheet file (.XLS format)
4. All of the above
Yes you can export to .xls below is the code that I use. It also does some sorting that you may not need or have to modify.
Basically it looks for the bom table and the puts that data in excel. There is some basic error proofing as well.
Good luck
Option Explicit
Private Sub CommandButton1_Click()
Dim swApp As New SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swTable As SldWorks.TableAnnotation
Dim bRet As Boolean
' If swApp Is Nothing Then
' Exit Sub
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
MsgBox ("Solidworks must be running and a drawing with a bom must be active")
Exit Sub
ElseIf swModel.GetType <> swDocDRAWING Then
Exit Sub
End If
Set swDraw = swModel
Set swView = swDraw.GetFirstView
Do While Not swView Is Nothing
Set swTable = swView.GetFirstTableAnnotation
Do While Not swTable Is Nothing
ProcessTable swApp, swModel, swTable
Set swTable = swTable.GetNext
Loop
Set swView = swView.GetNextView
Loop
End Sub
Sub ProcessTable _
(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swTable As SldWorks.TableAnnotation)
Dim swAnn As SldWorks.Annotation
Dim nNumCol As Long
Dim nNumRow As Long
Dim i As Long
Dim j As Long
Set swAnn = swTable.GetAnnotation
nNumCol = swTable.ColumnCount
If nNumCol > 5 Then
Exit Sub
End If
nNumRow = swTable.RowCount
' Get the table contents
Dim curRow As Integer
curRow = 0
i = nNumRow
Do While i >= 0
For j = 0 To nNumCol - 1
Cells(curRow + 4, j + 27).Value = swTable.Text(i, j)
Next j
i = i - 1
curRow = curRow + 1
Loop
' Move descrption column to the right by 1 column
Columns("ac:ac").Select
Selection.Cut
Columns("ae:ae").Select
Selection.Insert Shift:=xlToRight
'Sorts the bom data from SolidWorks
Range("AB6:AD104").Select
Selection.Copy
Range("H7").Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
' Deletes the SolidWorks data that was copied
Range("AA4:AE104").Select
Selection.Delete
'Go Home
Range("A1").Select
MsgBox ("Finished getting SolidWorks BOM")
End Sub
Private Sub CommandButton2_Click()
Dim swDrawModel As SldWorks.ModelDoc2
Dim sModelName As String
Dim nDocType As Long
Dim nErrors As Long
Dim nWarnings As Long
Dim strFileType As String
Dim longstatus As Long
Dim longwarnings As Long
MsgBox ("Solidworks must be running and a drawing must be active")
Exit Sub
Exit Sub
End If
' Drawing sheet
' First view on the sheet
' Determine if this is a view of a part or assembly
sModelName = swView.GetReferencedModelName
sModelName = LCase(sModelName)
If InStr(sModelName, ".sldprt") Then
nDocType = swDocPART
Else
nDocType = swDocASSEMBLY
End If
'MsgBox (sModelName)
Set swDrawModel = swApp.ActivateDoc2(sModelName, False, nErrors)
'__________________________________________________________________________________________
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim swModelDoc As SldWorks.ModelDoc2
Dim vDwgDependent As Variant
Dim strRev As String
Dim strRevResolved As String
Dim strConfig As String
'get custom property manager for modeldoc
'Set swCustPropMgr = swModelDoc.Extension.CustomPropertyManager(strConfig)
Set swCustPropMgr = custompropertymanger.g
'get revison value
swCustPropMgr.Get2 "Rev", strRev, strRevResolved
'display revision value
MsgBox "Model Revision is " & strRev & " " & "Config: " & strConfig, vbOKOnly, "Example Program"
End Sub
Select the BOM in the drawing field and do file>save as
Insert a file name and elect .xls as file type.
for BOMs inserted as Excel based you can also do this by selecting them in feature tree
That code doesnt work for me...comes up with lots of errors. It is for a macro correct?
Export SolidWorks BOM to Excel
I know it has been a long time but I came up with a solidworks macro to
export a SolidWorks BOM to Excel.
You have probably got it sorted but here is the link any way.
Welcome to dab-lab | Export SolidWorks BOM to Excel
You can copy the code off the site or download the macro
export solidworks bom to excel
You have most likley got it sorted. If not then here is a link to a macro I built.
There are full instructions on how it works. You can even download the macro.
Hope this helps
