Export Analysis Feature Parameters
  • Thread starter Thread starter megadeth0
  • Start date Start date
M
megadeth0
Guest
I have a distance analysis feature that I have patterned. That creates a
parameter value. I want to export all those values to a txt file or
something readable that I can drop into excel. There are approximately
100 analysis features in the pattern so doing it one by one is very time
consuming. Has anyone ever done anything like this?
Edited by: megadeth0
*Bump*
I never did find an answer to this problem, and I've run into a problem that I could really use this capability again. Has anyone been able to export a parameter list from an analysis feature to a txt file or something else that can be copied to excel?
Thanks for any help.
you can select those analysis features, right click>edit
parameters, then export them as text of CVS. open in excel
and do some data filtering.
solidworm: That export has to be done 1 by 1. I'd like a way to do it for a very large number of features all at once.
