R
Roland J
Guest
Guys I come from Inventor/SolidEge .. have been using Wildfire5 for ~4 months.
I'm trying to do an ISOMETRIC explosion, for use in a Drawing
It appears futile to construct an exploded view in the ASM file, with an intention ofbringing it into the Drawing (y/n?)... It seems the only way is to manage the default explosion as 'custom' one within the drawing's Model Tree ... ie: setting parts to explode/unexplode status & then painstaking selecting component entities as XYZ directions.
This seems a ridiculously difficult process, partly due to the default explode status being the starting point. The def/exp seems to send the parts in every direction ... consequently, with no perspective, it's difficult to realise whether are in-font or behind.
Why can I not begin with all Parts in their respective 'unexp' positions, & simply drag along an XYZ axis to the desired position & hit the ok button?
Many thanks in advance
