Error while opening a DXF file converted from PDF
  • Thread starter Thread starter saadicarnot
  • Start date Start date
S
saadicarnot
Guest
I converted a drawing in PDF format to DXF by using Aide PDF to DXF converter. The file was converted but as I open the output in AutoCAD I get a following error:
DXF read error on line 2275.
Invalid or incomplete DXF input -- drawing discarded.
Press ENTER to continue:
I have used Aide output in Autocad before and there were no errors for those files. It gives the mentioned error for only few drawings which I recently wanted to use in my Layout. Any help would be great.
Thanks.
Best regards,
Saad
