Jun 13, 2005 #1 A alfordtp Guest When there is an error message and it displays the mechanica ID numbers, how do I find what those ID numbers are refering to?
Jun 17, 2005 Thread starter #2 N Natewebb Guest You will never find those element ID numbers unless you are using the old Independent mode. If you have it, you can select Utilities, Macros, Replay_ID. That will highlight the element.
