sewy
- Dec 10, 2004
- 11
Good afternoon,
I think was enough spoken about this, but few modest questions I would have.
Equation
I was instructed to add interpart equations in assembly and link to each part. I do not understand how it works with configuration - which one solidworks chooses? In final result, if I change part conf. in assembly, equation stays previous. After ctrl+Q this subassembly stays not regenerated every time. Is this method right or is it better to add dimension from part directly to antoher?
Drawing views
Crop view stays emty in non ortoghonal sections, or after saving part.
How to make separate drawings of two similar parts or one part with several configurations? Through reference, there is problem this parts is swithech in assebly too (and everywhere is used)
System performance
I would like hear from you about stability of solidworks. From my experience, this sytem crashes randomly and frequently. Technical support has no answer about it. That means to save parts very often, but takes lot of time. And it's not an exception 'error while saving document' (something about this, I have german version)
Thank you for any response, I am beginner in Solidworks, until now used mainly Unigraphics.
My version is 2007 SP3.1
Equation
Drawing views
System performance
