bank
- Jan 7, 2003
- 74
There is probably a simple answer to this, but I haven't figured it out. I have had flow tests done on a dead-end water main, gotten residual and static head, and flows. My plan is to extend this main another 1500 feet to provide water for a new facility. I need to determine if the pressure in the line at the far end is adequate.
Can someone tell me how I would input the flow test results into EPANet to provide a source for the system I am designing. I tried using a tank and pump to simulate the condition at the source, but the results were not believable. I need help. Thanks in advance.
