Environmental Control Question
HishamTB
1
Hi Everyone,
I'm attempting to build a Climate control system for a project that involves gardening. Basically im looking to control the temperature (between 23-28deg) as well as the humidity (50%) of the inside of my isolated system that holds about 1 cubic meter of air and will be maintaining positive air pressure. The external environment temperature fluctuates between 26deg to 35deg and humidity is 90%. What should i be looking at for the cooling system?
I have thought of using an external water chiller hooked up to a radiator fan thats inside the isolated system to attempt to cool the inside but im not sure if thats the right approach. Any help is very much appreciated!!
Thanks a lot guys!
- Hisham
