Engraving in Sheet Metal.
  • Thread starter Thread starter shinujoseph
  • Start date Start date
S
shinujoseph
Guest
I want to create an engraving on sheet metal wall. How can i do that?
Will it be a forming operation?
Can anyone help me in that?
Thanx in advance
Joseph
Hi Shinu,
Engraving is a metal removal process and hence can not be categorized as a Metal Forming process. You can create the engraving on a sheet metal by the following two methods:
1. Extrude cut- on a flat surface
2. Surface offset- on a curved surface.
Please note that surface offset with draftoption is not directly available in sheet metal environment. However, there is a work around to achieve this. Please see the model tree in the attached picture below and I think you can understand what I am trying to explain.
Anand
Edited by: anand_m_s
Thnx
i got the soln by extrude cut method.
Joseph
