Endpoints,midpoints
  • Thread starter Thread starter Eureka
  • Start date Start date
E
Eureka
Guest
Is it possible to show midpoints,endpoints,etc on display while working in ACAD-Mechanical ?:confused:
Mid & End Points
So you would like to see the mid and end point of every line in your drawing all the time? I'm assuming you have used grip edit but you want it on permanently (Grips put small boxes around the Mid & End Points when you have selected the item without a command running)? What version of MDT are you running?
Yes indeed,
this is what I want to see. It's Acad MDT 2006
