embossed lettering around a circumference
  • Thread starter Thread starter north3
  • Start date Start date
N
north3
Guest
hi
i need to emboss some lettering around the circumference of a bottle im designing.
the lettering needs to go completely around my bottle not just a small part of it ( that would make life too easy !?)
can anyone suggest a way or somewhere i might find an awnser ( ive tried "search " but with no luck
thanks
To Create Text in Sketcher
Click Sketch > Text and select a start point on the sketching plane to set text height and orientation.
Click an end point. Sketcher creates a construction line between the start point and the end point. The length of the construction line determines the height of the text, while the angle of the line determines the text orientation. The Text dialog box opens. A green arrowhead appears at the start point of the text indicating the direction of the text.
Note: By default the dimension associated with the length of the construction line that defines the height of the text, is a strong dimension.
Under Text line, select Enter text manually or Use parameter.
Note: Use parameter is available only in the 3D mode.
Enter text manually
i think toroidal bend is the way to go
Edited by: north3
See Also
Useless copy and paste. What you pasted is the easy part, he wants to know how to do the hard part.
If I knew how, I would help him. Since I don't, I won't be pasting any useless info.
