mrtangent2
Chemical
- Nov 17, 2020
- 30
Apologies if this has been asked before for different levels of voltage is Medium 415 V, 11KV etc.. is there a minimum separation distance from mult-mode fibre optic cable?
or a design code which should be followed to design too. For a mixture of overheads cable racks and ducted cable runs. I'm looking to install a few 1000's of meters of cable on an existing unit and wanting to understand the design codes we should follow.
> Are the codes aimed at consequences of failure e.g. if the electric cable fails it would also take out the fiber cables ?
> are the separation distances aimed at actual impact on the signal ? (how can they be) as one is electric and one is light?
> are the separation distances aimed at reliability and long term wear from the impact of being too close to the electrical cable will eventually cause the fiber to fail? or do I need a certain type of fiber one less prone to damage ?
Thanks in advance
Thanks in advance
