Editing Text
  • Thread starter Thread starter Alanna
  • Start date Start date
A
Alanna
Guest
Can anybody tell me how to stop the text from rotating while editing.
Regards.
This might work, but...
... it may cause another change you don't want. MTEXTFIXED set to 2 shows text that would otherwise be difficult to read (if it is very small, very large, or is rotated) at a legible size and is oriented horizontally so that you can easily read and edit it. If you're zoomed out too far to read it, it will make it large enough to read. If it's rotated, it will make it horizontal while you edit, then put it back. Changing MTEXTFIXED to 1 gets rid of BOTH.
Is this what you're looking for? I hope so. Good luck!
