Editing a mechanical routing part 1
jerry1423
3,428
I have a mechanical routing part that has two ports on it.
I need to edit one of the ports and change its extension distance but cannot figure out how to do it.
Is it possible to edit an existing port on a qualified part or do I need to redo it?
Jerry J.
UGV5-NX1899
It is fully editable but you need to "be in the routing application" to do it.
1) Enter routing appl.
2) Find the "qualify part" button, you cannot double click ports to edit.
3) Click the "wrench button" in the qualify part dialog, from here it should be self explanatory.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Thanks very much Toost.
I just want to add before you press the wrench icon you need to select the port or whatever is being edited.
Jerry J.
UGV5-NX1899
