Edit Mtext?
  • Thread starter Thread starter Alarice
  • Start date Start date
A
Alarice
Guest
Hi to everyone,
When I create Mtext then mask it using the "express text mask" and if I try to access Mtext editor by double click mtext it only opens properties box. I have to un-mask mtext and then edit and then have to re-mask. Can any one tell me how the Mtext be edited without unmasking?
Thanks in advance.
Unmask the text, then use background masking and then you ddedit then select the text and you will be able to edit.
