Edit dimension in catia drafting?
  • Thread starter Thread starter dinesh_b7s
  • Start date Start date
D
dinesh_b7s
Guest
hi
Is it possible to edit dimensions in catia drafting, if yes how it could possible.
I cant edit the dimension in catia Drafting...........
What do you mean from"Edit Dimension"?
If you mean changing value of it, without changing that value in part, you can do it as follow:
Right click on the dimension -> Properties -> (first tab) Value -> (bottom of page, turn on) Fake Dimension and then you can enter a text or another number whatever you need. But remember that doing so is not very good way in drawing and also if you have to do so don't forget to UNDERLINE the faked value (because standards telling so)
